1 - 10 of 10 Posts
4C-Forums.com Vendor
This is one of the best Direct Replacement Air Filter available for your Alfa!
BMC has a long history of manufacturing some of the best quality air filters in the world. Their filters have been selected over all other high performance filters as the standard equipment filter for the European Launch Edition Alfa Romeo 4c.
OEM paper filters present an elevated resistance to the passage of air and consequently a reduction in engine performance. Compared to a paper filter the BMC air filter permits a notably higher air flow passage, producing less than half the Pressure Drop over the paper filters.
To get this BMC Performance Replacement Air Filter for your Alfa Romeo 4C please visit the link below:
Alfa Romeo - Alfa Romeo 4C Performance Air Filter by BMC - MADNESS Autoworks - Auto Parts and Accessories
Discussion Starter · #2 ·
Looking to replace the restrictive stock air filter in your Alfa Romeo 4C?
The principal difference between BMC oiled cotton filters and synthetic material filters is seen in the ability to retain air impurities.
Synthetic filters allow the passage of particles smaller than the size of the tiny holes in the filtration material. The cotton has a wider texture which favors a greater air-flow passage and through the combination of the different oiled layers, guarantees containment of all impurities from as small as 7 microns.
For the full details on this BMC Performance Air Filter for your Alfa Romeo 4C please visit the link below:
Discussion Starter · #4 ·
I recently had my engine oil analysed and found only the minutest contamination with silicates so I can verify the BMC filter works.
Thank you for your feedback Alfanut!
BMC makes some of the best filters on the market. Happy to hear it is helping protect your 4C!
Discussion Starter · #5 ·
BMC air filters are made of cotton, a natural material which can be reused several times after been washed with a special detergent and re-soaked in oil, thus saving the cost of changing it every time the vehicle is serviced and reducing wastes for the environment.
For the full details on the BMC Performance Air Filter for your Alfa Romeo 4C please visit the link below:
Discussion Starter · #6 ·
Discussion Starter · #7 ·
BMC's support frame structures are manufactured using a unique procedure called "Full Moulding" which enables the production of the characteristic red filter from a single mold without the need for gluing at the corners, often the cause of easy breakage.
BMC air filters have the smallest rubber infringement in the market (less than 6mm), thus allowing the maximum filtering surface.
To view the full details on the BMC Performance Air Filter for your Alfa Romeo 4C please visit the link below:
Discussion Starter · #8 ·
HIGHEST QUALITY
The BMC air filter is composed of a metallic mesh covered by an oiled multi-layer cotton filtration material. This guarantees a high level of filtering efficiency and a limited loss of air pressure.
The oil used gives the material its "sticky" adhesive characteristic which aids in the retention of air impurities, without compromising or blocking air flow penetration. This also creates a continuous filtering process. The cotton filtrating element is contained within an external support frame which interfaces with the air box and allows it to be securely installed in the air-box.
Every stage of the production process (from design to manufacturing) is carried out in Italy by Italian engineers using the finest materials.
For more information on the BMC Replacement Performance Air Filter for your Alfa Romeo 4C please visit the link below:
Discussion Starter · #9 ·
WINNER IN ALL CATEGORIES
BMC Air Filters are by far the most successful filters in every sports category, since they equipped the champions of Formula 1 (9 titles), American Le Mans (10 titles), Le Mans 24Hours (11 titles), DTM (9 titles), Superbike (2 titles), AMA Superbike (1 Title), Suzuka 8Hours (1 title).
Increase the Horsepower and Torque, and Improve the Gas Mileage of your car with one of the very best filters on the market!
For the full details on this BMC Direct Replacement Performance Air Filter for your Alfa Romeo 4C please visit the link below:
Discussion Starter · #10 ·
If you would like to see the full details on this Performance Air Filter by BMC for your Alfa Romeo 4C please visit the link below:
Alfa Romeo 4C Performance Air Filter by BMC for Alfa Romeo
1 - 10 of 10 Posts
