Ask Harri @AlfaNY . He’ll know.
Awesome, thank you!We suggest using torque value + angle where specified. We use middle value of what's specified (4.1 to 5.1 daNm), which would be 46Nm + 45°. It's important that the fasteners are loosened first.
It was exactly the same for me. The Nm torque brought it back to the original mark for most, and the angle added to that...The only thing I did not like about this was when I did my car I marked all the bolts first. Then loosened as per, but when the first torque was applied they ALL match the original spot. So then was adding additional degree to the bolt Which made me feel uncomfortable...did anyone else notice this
I think I’ll be setting the torque to just slightly above the lowest setting, cranking the torque wrench up to the upper bound, then going the +45*. That way, if it clicks over before I hit the full angle, I’ll know to proceed with caution.The only thing I did not like about this was when I did my car I marked all the bolts first. Then loosened as per, but when the first torque was applied they ALL match the original spot. So then was adding additional degree to the bolt Which made me feel uncomfortable...did anyone else notice this
