1 - 11 of 11 Posts
· Registered
Ladies and gentlemen, I've gone and done something very stupid.
I set out to replace my timing belt today. Got the belt kit and cam locking tools. Set cylinder 1 to TDC and fitted the crank lock tool. Then set out to lock the cams. Well, I am not sure if I had something misaligned or what, but the cam locking tools weren't just slipping in on the back of the head, so I (at least I thought) carefully tightened the bolts until the plates sat flush with the head. On the exhaust side, I heard a loud metallic "KINK" noise, which I initially thought was the plate settling. Finished the belt job which was pretty straightforward, went to remove the cam locking plates, and discovered that I broke the rear toothed section off the exhaust cam, and bent the intake locking tool out of shape. Don't ask me how, I don't know. Though it would be good to figure out what I did wrong so that I don't repeat it a second time!
Long story short, I have a broken camshaft to replace; I assume the part I broke is press fit on and can't just be replaced on its own. I priced out the stock cam, it's about $266+tax/shipping. Not terrible! I know I'll need cam seals and some RTV to reseal the cam cover, but if there's any other parts or special tools else needed before I jump into this job, please let me know. I'd like to have everything ready before tearing into it. I've done aftermarket cams on my old Toyota MR2 back in the day, so it's not my first rodeo in general, but I don't know if there's anything special about the process for this car.
Option 2 would be to upgrade to the Colombo & Bariani "fast road" cams at ~$1,500. I am usually a big fan of "if it breaks you must upgrade", but right now the car is only equipped with an Alfaworks tune on an otherwise stock engine (soon to get a downpipe and intercooler) so I'm not sure the cost is worth the potential improvement? I do use the car primarily for track so I'm not worried about losing low end power in favor of top end. However it seems like very few people have done cams other than Call Me Al whom I've already messaged.
Well, there you have it. A DIY cautionary tale. It's still cheaper than paying someone else, I guess!
· Registered
This is terribly unfortunate and I'm sorry this happened to you.
Just for future reference based on my own experience both camlocks will slide in completely flush without too much effort (and without tightening bolts) once the cams are aligned with the tools.
There should not be any need to force or pull things in via bolt tightening.
Hope it works out for you!
· Registered
Discussion Starter · #5 ·
Fortunately I don’t have to pass emissions in my county, and the eventual plan is to make the car a full on track-only car anyway.
Yes, very unfortunate. I feel quite stupid, but after a stiff drink, a good night’s sleep, and a trip to the gym I’m over it. Just need to push forward and fix it now!
· Premium Member
That’s the right attitude. We all end up in the “wtf happened” camp from time to time.
Nothing helpful to add other than I’m curious how it goes if you do upgrade the cam because (as you correctly pointed out) it doesn’t seem like many have done that.
Best of luck working through it.
· Registered
Discussion Starter · #10 ·
Well, I decided it would be more sensible and cost-effective to replace with another OEM camshaft, so I've just ordered that. I ordered two cam seals and may also replace my oil separator (or at least try a new gasket) as it seemed to be sweating. Hopefully the parts are readily available; thus far everything I've looked for has been available within a week, so fingers crossed!
1 - 11 of 11 Posts
