1 - 4 of 4 Posts
Hi guys
Probably there was already discussion about it but as more experiences as better the final alignments:
  • Negative Camber:
  • Toe in:
  • Positive Caster:
Can you write your best settings for track days in degrees units?
Thanks!
Remik, Rudi Gale (GMS) has posted his race settings. The rear settings are with his uniballs fitted and Nitron coil overs. Disclaimer: He’s a gun driver. What works for him and his car may not work for you. Take it easy.
Thanks a lot. I didn't notice Rudi's post about it so thanks also @GSM for your settins specs :)
I increased front camber from -0.5 to -1.6+, big difference at track especially. Note that lower studs might not allow to get much more shims if you have increased caster(for example AW blocks), but nordlock/wedgelock washers might allow some more.
1 - 4 of 4 Posts
