1 - 12 of 12 Posts
I've nearly finished making this for the rear cup holder. It started life as some aluminium guttering brackets which I melted down and then recast as this cap. It's sitting on a small 3D printed insertthat helps to keep it in place in the cup holder. The cap still needs a bit more sanding and then will be finished off with a clear lacquer spray. I'm doing something a little different for the forward cup holder - I'm just waiting for the 3D printer to finish the last bit. (I don't use the holders for drinks - mostly loose change.)
Alfa Rosso 2016 4C Spider + 1984 Ferrari 308QV Targa + 1981 Delorean DMC12 Grey Interior
Beautiful craftsmanship... Is it tight yet easy to open? What about etching a logo or QV for luck? Love it
Thanks. It's a little bit of a loose fit at the moment. I'll reprint the plastic insert that sits underneath so that it's a gentle push fit. The 4C logo is going on the next lid I do for the forward holder - here's the 3D printed mock-up. I'll try to make a casting of this in aluminium again.
I am certain if you can create both pieces (lid and Aluminum "Cup" Insert) to replace the OEM plastic holder (at a reasonable price) you might have 100+ sales just on this board! :)
While time makes sad jokers of us all, at least we had the luck and strike to get and slide about a thing like an Alfa, and its the little things. The Alfa lets a dude abide, good call
1 - 12 of 12 Posts
