1 - 20 of 22 Posts
4C-Forums.com Vendor
Give your Alfa Romeo 4C a more aggressive stance and improve the handling at the same time with these High-Quality Italian, Custom Wheel Spacers by Athena!
The combination of the best materials, special design, and precise manufacturing process make these custom wheels spacers the only choice when it comes to picking a set of wheel spacers for your vehicle. These spacers also come with TUV-Certified Hardware, because your safety is important!
Athena Custom Wheel Spacers are precisely machined from a block of top quality aluminum using CNC tooling machines to guarantee maximum precision. No welding is involved in this production process. This process gives the spacers unbeatable strength for an added level of safety.
Athena spacers for the 4C come in 5mm, 16mm, 20mm, and 25mm sets with bolts.
More information and pricing can be found on our website
https://madnessautoworks.com/index.php?route=product/search&keyword=athena
Let us know if you have any questions
Discussion Starter #4
Fixed your title for you.
"Custom heel Spacers" just wasn't doing it for me! :wink2:
Thank you, that one made it past our checks.
Are they available in black?
Not as standard. We could potentially do a custom powder coat. If that is the route you want to go shoot us a DM and we'll work out the details.
Discussion Starter #5
Have you ever wondered what your Alfa Romeo 4C would look like with spacers?
We carry a vareity of Athena wheel spacers in various sizes for the 4C. Below is a customers 4C fitted with 25mm rears and 16mm fronts.
More information can be found on our website
25mm
https://madnessautoworks.com/2018-Alfa%20Romeo-4C/alfa-romeo-4c-wheel-spacers-by-athena-25mm-set-of-2-w-bolts-pid812
16mm
https://madnessautoworks.com/2018-Alfa Romeo-4C/alfa-romeo-4c-wheel-spacers-by-athena-16mm-set-of-2-w-bolts-pid7712
Discussion Starter #6
Looking for that perfect fitment on your Alfa Romeo 4C?
This customer came to us with the goal of flushing out his wheels and we set him up with the perfect spacers for the job. 16mm fronts and 25mm rears.
The Athena spacers are hub centric TuV approved spacers from Italy and they include extended bolts. Giving you everything you need for a seamless install.
Contact us or visit our website for more information
I've been running 15mm fronts and 25mm rears. The non anodized/powdercoated color blends in with the hub so you do not notice it at all when looking through the wheel.
Discussion Starter #11
Do the front spacers chip any of the paint around the wheel arch?
Thsnks in advance.
The spacer itself is on the hub so it can't touch any of your paint. Now if you go with a large spacer and really poke your tire out from the fender you could get more road debris flying up from the tires.
Discussion Starter #12
Get that flush look on your Alfa Romeo 4C with these custom Athena wheel spacers!
Athena makes some of the best spacers in the game right now and these carry TuV approval to certifiy their great build quality and materials.
These are hub centric spacers designed specifically for the 4C so there is no wiggle room once mounted. Which will ensure that your lugs to not bear the strain like other spacers.
Contact us directly or visit our website for more information
https://madnessautoworks.com/Alfa Romeo/start-shopping-cid1/new-arrivals-cid2/alfa-romeo-4c-wheel-spacers-by-athena-16mm-set-of-2-w-bolts-pid7712
I'm considering getting 20mm spacers for the rear only. I have the Alfaworks front suspension blocks fitted, so don't need spacers at the front.
I want the wheel nuts/lugs to look the same on all wheels.
Can you get the lengthened bolts for these Athena spacers to match the stock 4C wheel nuts/lugs?
I guess the other alternative would be to replace the stock front wheel nuts with chrome ones, but I think the stock ones would look better...
I have the rear 20mms on mine and love it. No front wheel spacers. The stock lugs will match the front. The black lugs you get with the spacers are not seen
Discussion Starter #15
We just had a customer do a great review on the Athena Wheel Spacers for the 4C.
Here it is below!
As always, if you have any questions or concerns please don't hesitate in reaching out.
Dear Madness,
Do the 20mm Athena spacers have the longer straight through bolts, or the same configuration as the 25mm spacers (which bolt to the hub with separate bolts and then use the stock wheel nuts to bolt the wheel to the spacer)?
The pictures on the Madness site indicate the long straight through bolts, but the post above from Texas4Cforever suggests the 20mm spacers have the same config as the 25mm spacers, so I'm confused.
And do you ship to Australia?
Matt
Dear Madness,
Matt
Ok Madness, I have somewhat a similar question. I want to do the 25mm on the rear only. The way I understand it is that you supply the bolts for the spacer to the hub and then I use the stock bolts for the wheel to the spacer, Correct statement? Also, the spacer is silver and can I do the rear only? Ty...
Discussion Starter #18
Dear Madness,
Matt
Matt,
The 20mm spacers come with extended length wheel studs which are different than the 25mm+ applications that come with flush mount allen bolts that mount the spacer to the hub and your stock wheel bolts hold the wheel to the spacer.
We ship globally so we have you covered!
Yes, that is correct. The allen bolts that come with the 25mm spacers recess into the face of the spacer (providing a flush mount) attaching it to the hub. Then you use your factory wheel bolts to mount the wheel to the spacer.
Matt,
Perfect, ty. I just ordered a set of 25mm for the rear. Can you please confirm the torque # or is that included with the spacers?
Discussion Starter #20
Hi Rags747,
Just wanted to reach out to you and state that here at MADNESS we use 75ft-lbs. I hope that you are enjoying the Wheel Spacers.
Let us know if there is anything more that we can be of assistance for you.
1 - 20 of 22 Posts
