Try getting one of those flexible form-a-funnel things. I use it to divert the dripping oil. I see you have a good catch pan, but the bigger the better. Restaurant busboy table clearing bins are the best. That dedicated drain valve probably works well but have not tried it. I guess another advantage of it is you don’t have to keep replacing the relatively hard to find drain plug crush washer with the rubber inside edge. Also not a fan of backing onto those plastic ramps. I’ve seen occasions where they’ve slipped past the rear drive wheels and then you’re screwed. I lift mine with jacks on the dedicated lift points.
