Start with the 1/N/R/A/M selector panel.
Pop out window/side mirror switch panel from underside from now removed selector panel. Disconnect harness.
Locate the 4 10mm mounting posts with nuts. Carefully lift up that console piece and turn over to be able to access and disengage the Hazard and DNA selector harnesses. There is a guide pin at the rear of that console piece that seats and aligns that front piece with the rear piece.
Undo and detach ebrake boot
