I would suggest using a plug into the 12v recepticle that has 2 wires. Then you can plug it in and remove it as needed.I need to tap an accessory 12V source in the cabin and was aiming to tap the 12V plug harness. Do you know which wire is the 12V source and which is the ground? Alternatively, is there another spot to source ACC power and ground (for reverse mirror power).
