All,
I have finished replacing the clutches in my car, and there were a lot of points that didn't have clear direction, so I went ahead and made a rudimentary instruction manual. For anyone who is considering doing this job, I'll tell you it isn't for the casual weekend DIYer. There are a LOT of steps, and several steps where you can damage things if you don't do them right. That said, if you have access to a lift and both mechanical and some computer know-how, along with a buddy who can help and a couple weekends available, then read on.
I'll start by saying that I had to do this not once, but twice. It was brutal. I had a leak coming out of my transaxle input shaft, which caused my odd gear clutch to slip. I took everything apart, replaced the input shaft seal and clutch pack, and then after putting it all back together, it immediately started leaking again, ruining my brand new clutch. The leak was caused by a bad inner bearing inside the input shaft. Since I didn't replace that, I had the issue all over again. See my video here for the symptoms of a bad bearing: Alfa Romeo 4C Bad Input Shaft Bearing
Special thanks to my friends Bill and Jeff for all their help in this long journey, and also to @Alfa9 Supply @jamiealfa for supplying the parts and advice when I got stuck!
In addition to my DIY, you'll also want to have the 4C service database available at your fingertips (The 4C Cloud - Table of Contents) at the very least, though I actually recommend buying the official TechAuthority manual USB stick (Buy Mopar Approved Service Information). This is from Alfa corporate and all the hotlinks work, making it much much easier to navigate for a challenging procedure like this one. You'll also need to have the AlfaOBD software up and running to do the calibration procedure before starting your engine.
Here's the link to the DIY:
ClutchReplacement.pdf
