Awesome! I love to see how things look underneath but I'm to chicken to take them apart myself.
Everything just snaps back in place. Its very easy to do.As long as you put it back together without any spare bits left over.
I assume the panel popper would make the job easier as it would apply the right amount of force. I just move my hand right to left pulling gently. Seven push in screws.When I was working as an Auto Stereo Installer, we had a tool we called a "panel popper". It was like a wide putty knife with a notch in it to go around the panel clips. This helps to not bend or break the panel.
Did you roll the bottom edge of the panel away from the frame a few inches, then lift straight up to release it at the window?
The speaker looks as cheap as it sounds. I'd like to see what's behind the speaker. How deep is it? What are my options for a real speaker?
Tweeter must be mounted to the panel. I don't see it on the door frame.
I think I'll give the honor to someone else to do a 'bonnet removal'... unless like you said I find someone else's car to sacrifice.>Excellent love these posts and vids of how its made/how do they do that
Love to let others go first, like Tallinn too chicken, without fail will have bits over
Can you do step by step bonnet removal next Alfa4Clover
and its not even your car:surprise:
already seen this on a thread somewhere. God knows where though!Excellent love these posts and vids of how its made/how do they do that
The tool slips up under the panel without flexing the panel, then pressure can be applied more evenly. As the panel ages, it becomes more delicate. In working on older cars, the panel breaks quite easily without a tool.I assume the panel popper would make the job easier as it would apply the right amount of force. I just move my hand right to left pulling gently. Seven push in screws.
thank you so much for thisEverything just snaps back in place. Its very easy to do.
I doubt these pushin rivets or screws will last 3 or 4 attempts though.
