Hi @morcheen
Could you check the depth you get from the adapter to the mechanism for me 🙏🏻.
I’d like to go with the PS130FE, but these are deeper at 60mm.
Thanks!!!
See:
Thanks!!!
See:
@flyt100 The ISU 130 has a depth of 48.9mm. Do you think the PS130FE with a depth of 60mm would fit as well? (1.93" vs 2.36").
It would be really tight, but it may be ok. I installed a set of Hertz speakers that are 57 mm deep.
I assume you are using the angled speaker adapters? I'm guessing you'll be fine in that case, but you'd have to try. You are trying to avoid this part of the window mechanism:
As a comparison, if you placed the 130 directly in the hole (I'm not recommending that, just for sake of argument), the lower side of the magnet just touched the upper side of this spring. WIth the offset and angle of the adapter, it wasn't near it at all. It all depends on the depth and diamater of the magnet.
