Nice numbers. Some say the oiled K&N filter can lead to elevated silicon levels as well. Either way, your engine looks good.
I think you're correct re silicon. How do you like your setup with the clone? Have you tried launch mode yet?As mentioned earlier in this thread, I had virtually the same setup as Mankind. Pogea Clone and hoses, K&N Filter, Madness Exhaust. Just changed oil for 2nd time. First was at 3600 miles and this one is at 7300 miles, so this oil saw 3700 miles. The only out of whack reading was the Silicon. Everything I have read suggests this is not uncommon for new engines due to the gasket sealers that can be used.
My fuel contamination was <2.0 which is great. I was worried it may have been higher. Anyway, official report attached.
Looking forward to those!.... I will publish my Auterra results soon.
Sounds like over-oiled to me.I never had good experience with K&N air filters. The oil on the filter gets into the MAF sensor and coats it, sending incorrect air/fuel measurement to the ECU and causes all sorts of issues. I cleaned the intake hose and MAF and they were oily and filthy inside. Used in my 164 before and failed smog test until I removed it, then the car passed with flying colors. I have never used K&N since.
I was reading about this issue on Eurocompulsion sales page for the Sprint filter. This is why they don't sell K&N to fit the 4C. Interestingly, Madness sells and recommends the K&N in the 4C for improved performance.I never had good experience with K&N air filters. The oil on the filter gets into the MAF sensor and coats it, sending incorrect air/fuel measurement to the ECU and causes all sorts of issues. I cleaned the intake hose and MAF and they were oily and filthy inside. Used in my 164 before and failed smog test until I removed it, then the car passed with flying colors. I have never used K&N since.
Ha ha! Sorry. I just don't look at having to jack up the car, remove the wheel, remove the inner fender liner, just to get to the filter being EASY!Sounds like over-oiled to me.
Thousands of us use them without issues, you know!
:wink2:
But I prefer the idea of the sprint. Much easier to take that off, clean it with air, and put right back on instead of having to solvent-wash the filter, let it dry, and then re-apply the oil first.
Fair comment.Ha ha! Sorry. I just don't look at having to jack up the car, remove the wheel, remove the inner fender liner, just to get to the filter being EASY!
As other have alluded to, this is usually more about "user error" than MAF sensor sensitivity. I've used K&N's in multiple cars (normal everyday cars and specialty cars as well) and have never had any issues.I never had good experience with K&N air filters. The oil on the filter gets into the MAF sensor and coats it, sending incorrect air/fuel measurement to the ECU and causes all sorts of issues. I cleaned the intake hose and MAF and they were oily and filthy inside. Used in my 164 before and failed smog test until I removed it, then the car passed with flying colors. I have never used K&N since.
Having a car jacked up for 24 hours is just silly (and I'd argue slightly risky...). The reality is, get a second filter and you are set. These things are way cheap on Amazon. Not sure about you guys, but my time on turning maintenance is way more of value to me than a one time cost of an additional $60 bucks for an extra filter. Also, it's just easier to remember to swap it out in sequence with your oil changes. You then wash and air dry at leisure.Fair comment.
But it is still easier to do the air-cleaning than to keep the car jacked up for 24 hours while you wash, dry and re-oil the K&N or BMC filter. Or drop the car and put it up again a day later...
...As was suggested previously in another thread, having a second oilable filter is a good option. But that gets expensive too, considering it is only saving you one day every year or two!
So basically just like Pogea himself.The Pogea was not as smooth at part throttle and had "holes" in the feel of acceleration. The Pogea was also much more drastic and wild at full throttle from a stop. It would bark...
Thanks for the information on the Honda engine - do you know the years of manufacturing affected by this?Maybe it's me, but did I read someone from Mobil come on here and not eliminate the biggest blunder I might have ever seen. Did I just read that someone threw in 0 weight oil and then, as an employee of Mobile, go on to ponder about oil diluting with fuel? I read that -- right? I am not even going to scroll up to see it again!
Another thing I see developing: Justifying (wrongly) why doing X (not approved) is ok, instead of Y (which is approved). STAHP
The wrong oil at cold start is the FIRST variable to be eliminated. Of course 0 weight oil is not want you want to go to war with when the type of engine (DI) that is more prone to oil dilution is coming to life on a cold, rich, wet, sloppy tune in a car that will take forever to warm up.
There's more, such as hints about the type of driver and driving, which is present in the language and... I can't. Why am I here?!!? WHY?
Driving at a given cruising speed is meaningless in these discussions! Highway speeds!?!!?! You can drive all day at highway speeds and not run at a truly meaningful temp!!
7 miles... 7 minutes... 100-130 KMH.... whatever! Tells us DIDDLY SQUAT (nothing).
I mailed my sample for analysis on Monday (15/3/20) and will present the results when they are received. My oil of choice is Amsoil 5W40 European Formula Classic.Thanks for the information on the Honda engine - do you know the years of manufacturing affected by this?
As for me, being a Mobil employee and going against OEM recommendations, yes! ? This is simply to say I will be biased toward a Mobil product...that does not meet the Chrysler spec OR Fiat spec OR fulfill the ACEA C3 requirements.
What I AM saying is that we are all likely getting fuel in our oil, regardless of the viscosity written on the bottle. This is based off other members' oil analysis as well as my own. There is much discussion about the proper oils to use during our oil changes to meet the approved specifications. We are not all here using the same oils and I'm not plugging Mobil. Ideally the multi-grade oil should fulfill both the cold and operating temperature viscosity requirements, in this case 5W-40. And in the oil I am using, 0W-40, it does cover that entire range. If you or I have a 5W-40 oil, this isn't going to change the fact there is fuel dilution into the case. The viscosity grade at operating temperature is the critical factor here as the engine will eventually warm up. The viscosity value documented in the oil analysis report is taken at 100C, meaning there is fuel dilution still occurring during operating temps, and sure, it'll be more likely during warm-up too.
I have discussed this with Greg at EuroCompulsion and he had some great insights on the functionality of our engines. Two of the most likely reasons may be leaky fuel injectors and/or boost development during the warm-up process. One is corrected by habit - albeit patience not being one of them ?. Perhaps all new 4C engines have leaky fuel injectors, and this can be investigated. The habit one will require more time and control.
If the fuel will continue to dilute the oil, the only solution I can think of at the moment is to blend the oil with a higher viscosity to compensate for the fuel dilution lowering the viscosity. This is not recommended, but if the oils are within the same product family, the additive packages are essentially the same and the difference would be the base oil viscosity. Not sure if I am going to try this without some more homework. I will keep you posted on my next oil analysis...Currently awaiting the EC Phase 2 tune.
