1 - 11 of 11 Posts
4C-Forums.com Vendor
EUROCOMPULSION COMPLETE INTER-COOLER HOSE KIT
EUROCOMPULSION Complete Inter-Cooler Hose Upgrade for the Alfa Romeo 4C. This Kit includes our KEVTEK European Silicone and stainless steel clamps. This kit is a direct replacement for the factory rubber hose. Our Silicone has a thermal conductivity that is less than half of the factory rubber, which will keep the extreme heat from the exhaust and turbo at bay prior to entering the Inter-Cooler, which result in lower charge temps and increased inter-cooler efficiency.
Our silicone with its Kevlar Aramid reinforcement will last the life-time of the vehicle and will never need to be replaced. Enjoy improved Aesthetics that look the part, without over being over the top. Will fit North American, European and Australian based vehicles. Perfectly paired with our updated V2 Air Induction Kit.
FEATURES:
  • Will Last the Life-Time of the Vehicle
  • 5-Ply European Silicone with Kevlar Aramid Reinforcement
  • Increased rigidity to further resits extreme temperatures
  • Smoothed bends and interior walls reduce air turbulence
  • Includes all (3) Silicone Hoses and Stainless Steel European Clamps
  • Improved Performance; paired well with Euro+Drive Clone or a Stock Vehicle
  • Extremely Low thermal Conductivity = Increased Efficiency
  • Our Kevtek Silicone will withstand 150+psi and 800+F
  • Keeps Air Temps from Turbo & Exhaust cooler when entering Inter-Cooler
  • Perfectly paired to our Euro+Drive Clone Phase 1 and Phase 2 Calibrations
  • Will Fit North American, European & Australian vehicles
  • Available in a Deep Red Exterior and Black Interior Colored Silicone
  • Direct factory replacement
Price: $424.99
WEBSITE: https://shopeurocompulsion.net/collections/alfa-romeo-engine/products/eurocompulsion-complete-inter-cooler-hose-kit
EURO+DRIVE PEDAL PRO
The EURO+DRIVE® Pedal Pro is an electronic throttle control module that allows powerful end user customization and pedal response tuning done easily on the fly. The Pedal Pro's sleek and compact design offers easy installation and discreet use with a simple to use interface. 3 modes, 17 different settings, and multiple features such as anti-theft mode, full throttle launch, and snow mode.
The EURO+DRIVE Pedal Pro is made to be compatible with all EURO+DRIVE Flash tuning and is programmed not to interfere with full throttle tuning parameters and trims at full load.
FEATURES:
  • 3 Modes, 17 Settings
  • Sleek Compact Design
  • Full Throttle Launch / Snow / Anti-theft Modes
  • Simple Installation/Removal - Completely Plug & Play
  • 3X 1000/sec Micro-processors
  • Mimics ECU Throttle Signal
  • Prevents Signal Input Overload
  • Suitable for Stock to Heavily Modified Vehicles
  • Fully Compatible with ALL Euro+Drive® Calibrations/Products
PRICE: $279.99
WEBSITE: https://shopeurocompulsion.net/collections/alfa-romeo-engine/products/euro-drive-pedal-pro-alfa-romeo-applications?variant=3645225631784
EURO+DRIVE ALFA ROMEO 4C DIRECT TUNING
The EURO+DRIVE® DIRECT Tuning System is an economical solution in loading calibrations on your Alfa Romeo 4C. Using genuine Alfa Romeo 4C based software, protocols and calibrations, we have increased drive-ability, power and throttle response. We are proud to have the ability to offer you the most comprehensive tuning option for your Alfa Romeo 4C. Each purchase includes our calibration loaded onto YOUR Engine control Module. Designed and developed in the USA.
NA/EU/AUS ECU DESIGNATIONS DEFINED BY SHIPPING DESTINATION.
EURO+DRIVE® CLONE/DIRECT FEATURES:
Specifically designed Calibration for the Alfa Romeo 4C
AVAILABLE FOR THE US & WORLD-WIDE MARKET
Use of Genuine OEM Software,Maps and Protocols
Simple 5 min INSTALLATION/REMOVAL
Preserves factory ECU/WARRANTY (with Clone Selection)
Calibrations will Optimize power, drive-ability, and efficiency
Unparalleled consistent, linear, & smooth power delivery
Calibrations retain all OEM tuning logic
Calibrations retain all Safety Parameters
Calibrations retain sensor based learning
All factory hardware works properly
Full control over all engine parameters by utilizing true factory Calibrations
Specially requested Calibrations available (additional fees may apply)
91oct minimum fuel requirement (Please see Phase 2 Requirements)
No Gimmicky add-ons
Strong & Reliable power through-out the RPM band
Informational Videos Below
EURO+DRIVE® DIRECT STATUS:
294+WHP* PHASE 1 RELEASED/AVAILABLE
320+WHP* 361PS/472NM PHASE 2 RELEASED/AVAILABLE
3XX WHP* PHASE 3 IN DEVELOPMENT
As these cars begin to come out of warranty we have made direct tuning available at less than half the price of the clone units. We apply the calibration of your choice to an existing ECU,
whether it be one that already has a calibration or factory file
PRICE: $999.99
WEBSITE: https://shopeurocompulsion.net/collections/alfa-romeo-engine/products/euro-drive-alfa-romeo-4c-ecu-clone-system
Dude
Go to their website
The införmation is there.
It's how the internet works.
BTW E. C.
I love how you use high quality worm clamps vs t-bolt clamps.
Good worm clamps apply 360 degree worth of clamping pressure
All T-Bolt clamps have a flat spot which can result in a boost leak or worse, a bent pipe if over tightened.
Discussion Starter · #6 ·
Where is this company located? The ECU needs to be sent? is there a shop in LA?
We are located in Oklahoma and NY.
The Direct calibration requires you to send the unit to the Oklahoma address listed on the website.
The Clone version does not require an ECU to sent in.
Chris, I have your older version of the 2 top and bottom IC hoses. Do you offer just the 3rd hose on it's own? If so, do you have it in black like the older ones, or just the red kevtek.
I did. Did not find their location info. If is there, is my bad
It’s in the contact page under Company Information and they also have a page for trusted installers in a variety of different states
It's been a while since I did the V2 intake that had a hose.
Are these 3 hoses separate or is one of them the same hose as that install?
1 - 11 of 11 Posts
