A bit more about OCC in 4C.
By placing a breather filter (small filters you usually see on some car builds), is not the best idea as you turn closed crankcase venting system into open. 4C would need to have 1x breather filter on the vacuum side (left outlet of the red circle) and 1x breather filter on the boost side (right outlet of the red circle).
By having a breather filter on the left outlet of the red circle, you would change the closed PCV system into open PCV system, allowing the positive pressure in the crankcase to vent into atmosphere, dispersing oily mist in to the engine bay, but at this point you've already lost a vacuum in the PCV system which is not good. Also, under light load and cruising (vacuum) the fresh air will be sucked through the left green circle, adding unmetered (MAF doesn't know this air is coming in to the engine) which is not good, so you would need to blank this port. The same goes for having a breather filter on the right outlet of the red circle, except it is working under high load (boost) situations while the PCV NRV (non return valve) closes. With this setup you are allowing the positive crankcase pressure to be vented into the atmosphere, but you are loosing both vacuums and unless blanking the green circled ports, also providing unmetered air to the engine, messing the AFR ratio. Not good.
Keeping the 4C stock PCV system as it is, works good enough to let the car pass emission standards, requires no special maintenance, but on a long run, the amount of blowby we have, especially tuned engines, will mess your engine internals. The oil sludge and carbon build up will occur and DFI (direct fuel injection) engines are notorious for it. When it does happen, you can remove the intake manifold and take it for a cleaning. Usually, walnut blasting does the job, but it is not the easiest job and as you don't want any of the blasting particles to get in to your engine valving. Not exactly a DIY unless you are skilled mechanic. Also get ready to get charged quite a few hours of labor and if someone says it can be done in an hour or so, I'd stay away from it. Even though you cleaned your valving and intake, there will still be oil in intake piping (intercooler, throttle body, etc.) and sooner or later you will need to do this again. You cured the symptoms but not the source of the issue.
By installing closed system OCC you keep the much needed vacuum in the crankcase and prevent the oil entering the intake tract. The only reason manufacturers don't use such systems is added cost, emission regulations and fact that people want to turn the key and drive, no one wants to bother with the amount of oil in the OCC.
