I got an interesting question today. Why does 4C require twin OCC setup?
A simple and short explanation to the question would be. Older engines usually run single, simple venting system of crankcase as they are not prone to a carbon build up due to the fuel being injected before the intake valves and consequently cleaning the valves. Newer DFI (direct fuel injection) engines, like 1.75 Tbi is, require more sophisticated crankcase venting to prevent carbon build up as there is no fuel to keep the valves clean as the fuel is injected directly in to the cylinder instead pre-valve. So in 4C double oil catch cans are needed as there are two venting ports. One venting port is in the intake manifold which works when engine is under vacuum (light load, coasting or cruising), but as soon as the boost generates, the NRV (non-return valve) closes this port. Under boost, second port which is before turbo starts to take the function of crankcase venting until the engine goes into vacuum mode again. Combining these two would cause interference of venting ports in between, and the use of additional vacuum NRV on both OCC OUT ports doesn't work correctly either. So double OCC (oil catch can) system is required. The riddle can’t be solved with single OCC, neither with dual IN and single OUT OCC. It could be solved with separated dual IN, dual OUT OCC, but that is basically a double OCC setup.
I hope I explained it reasonably, but if anyone really wants to visualize the issue, it's probably gonna take some drawing as things get quite complicated with all the vacuum flowing within the hoses.
