1 - 20 of 23 Posts
Hi All,
I decided to replace the handbrake black stitching with red 0.8mm polyester waxed thread
While busy removing the black thread, thought a cross stitch would look more elegant, using 2 needles
Some photos of the process are displayed below
Auto part Technology Wire Cable Vehicle Gear shift Auto part Vehicle Center console Car Gear shift Vehicle Auto part Car Mid-size car
Next was to replace the black double line stitch of the handbrake pouch with red 0.5mm polyester waxed thread
Some photos are displayed below
Footwear Joint Zipper Leg Shoe Footwear Shoe Ankle Zipper High heels
Result of both in the Alfa 4C is displayed below
Gear shift Vehicle Center console Car Auto part
Now busy replacing the black stiches of the door handles with red 0.5mm polyester waxed thread
Door handle is shown below
Vehicle door Audio equipment Fashion accessory Vehicle Metal
2016 4C Spider + 3 Ferraris + 6MT 997.2 RWB'd
Please... Please do a small writeup and pics of tools used! Maybe it's obvious to buy the polyester and restring with needle but some of us will be doing anything like this for the first time and would appreciate any tips and methods. I will be doing my brake boot and handles too!
Bellissimo, well done!
Thanks will do a small summary on what tool/needles/thread I used
Discussion Starter · #7 ·
As requested : the tools I used for this work
When stitching leather only waxed polyester thread should be used, this slides much easier through leather and is more dirt resistant
After a piece of stitching is finished (like the door grip) a flame is used to melt the end of the thread (so it stays put)
0.8mm thread thickness I used for the handbrake only, two non-pointed needles of 1.05 x 55mm
Twine Material property Textile Fashion accessory Label
For the other work (is a bit more complicated) I used :
0.5mm waxed polyester thread spooled on a Sewing Awl (sharp needle, like a sewing machine needle was inclused)
To work more easy I used a needle of 0.9x48mm on the other side of the leather (is explained later)
Copper Scissors Metal
The Sewing Awl spooled already with 0.5mm thread:
Wood Copper Fashion accessory Jewellery Metal
Small explanation delivered with the Awl:
Line art Drawing Text Black-and-white Sketch
Few steps below show how the Awl is used on the door grip:
Fashion accessory Wood Strap
Pushing the needle through the leather using the original hole
Now you see the use of a needle on the other end of the thread:
Wire Cable String instrument accessory
Next the thread is pushed through the little loop, easier to be done when a needle is used:
Wire Cable Technology Electronic device Electronics accessory
Next you draw back the Awl and hold the thread on the other end, then you pull both ends tight
and ready for the second stitch...
Wire
For those looking for the sewing awl....try Ace Hardware if in the US. I have one but used it to repair what are known as sew-up tires on my road race bicycles a few years back.
I tried to do the same with my door pulls (in yellow). With the same tools, I couldn't get the thread through all the layers; and if I did, it looked like crap. Nice job @Henkjan !!
Discussion Starter · #12 ·
Hi, with the sewing awl it should work to get the needle through using the same holes (after removal of the black stitched thread of course.., then when putting the wire through the small loop, make sure your pul both sides to make it tight
If it's an LE I believe original, don't think others had it. I know my spider from 2018 doesn't have stitched handles, has majority of options so if available would think I would have it.
Definitely not an LE.
1 - 20 of 23 Posts
