Ingenious!
Thanks for writing this up and adding the photos.
I’ll post a link to this thead in the DIY index.
yes. perfectly.Can you guys see the whole gauge now? Finally! I asked this question not so long ago.
This is a big deal. A big problem was solved. This was the reason I waited so long to buy a 4C.yes. perfectly.
yes. it's slight and subtle at the bolt point but 5 washers adds 3 -3.5 inches in viewingSo what is going on here? You're dropping the back so that the front has great upward angle/height?
Did you loosen the lever that allows steering column adjustment? Without loosening it, I couldn't move the column. Then I was loosening the top two nuts (the ones closer to you) bit at the time until I could squeeze in the washers one at the time on the back bolts.Thanks so much for posting this. I'm also 6'4" and the obstructed view to the screen makes me nuts.
I'm struggling with the last bit of this. I've got everything exposed and loosened, I've got the two bolts nearest the steering wheel virtually to the last thread but I can't lever it enough to get the back of the column off the studs to place the washers. I'm contemplating removing all four attachment points and resting the whole column onto the crossmember that's beneath. But I think the better bet is to go get two other bolts the same spec as the two stock bolts nearest the steering wheel but longer. Replace the two stock bolts with the longer ones temporarily to get another inch or so of leverage. That should allow me to place the washers, then re-assemble.
