This must be my third version of how to jack up our cars but I’m convinced this is the simplest best way now. Not sure why I didn’t figure this out earlier.
Parts needed:
I small low jack with decent reach.
4 flat top jackstands modified so they go lower.
Inokinetic 4C Liftkit
This is all you need to secure the car in the air on 4 jackstands. Not sure why I didn’t figure this out earlier but today at the track I had to change the front and rear brake pads. First time I’ve had to do both at the same time. OMG The front pads are so much easier than doing the rears!
Sequence:
1. Jack up the entire rear of the car using the 4C Liftkit area which is the center rear of the car.
2. Put your 2 lowered jackstands at the two rear jack pad areas of the car.
3. Then bring the jack to one side of the front and slide the jack into the inner lift pad area of the car (in the front there are actually four lift areas 2 inner and 2 outer).
When you lift the front of the car using one of the inner lift areas the whole entire front of the car will lift. When I just do tire changes I just use two jackstands in the rear and only the jack in the front. But of course when I do brake jobs or anything where the car needs to be secure for awhile I use the 4 jackstands.
5. If you are going to put the front jackstands in place you have to angle the jack pointed in about 45° back towards the rear of the car so you have room to put the front jackstand on the outer lift area of the car in place.
6. Put the two jackstands on the front outer lift areas.
That’s all there is to it. Just reverse the sequence to lower the car.
Note: you have to modify these jackstands to make them a bit lower or they will just be too tall for the front at least. No need to drive the car on two pieces of wood or anything like that using this method.
Here is the parts are used. Other jacks might work too but I like this jack because it has dual pistons and is quite low, very lightweight and reaches in quite a bit. It also fits into a plastic crate. You can even put two of them in one heavy duty plastic crate.
And I really like these jackstands because they are secure, nice and flat with a rubber top. Also can be modified to be quite low.
I also highly recommend this Racer Mat sold by sold by Race Ramps. Lightweight comfortable pad to knee or lie on and you can just set your tools on it and then drag them around the car on it!
Happy jackin!!
Parts needed:
Sequence:
Happy jackin!!
