I had disconnected the CAN-OUT and KEY cables (for no reason) and it turns out if they aren't connected the remote doesn't work.What was the issue with the remote?
You are right there probably is and I searched the forum, but found some people saying they had no luck. I thought I would be able to use the built in mic, but I guess not. For now I am just going to let it be real ugly, I want to drive and work on the exterior polish more.Is there really not an adapter that will make the stock mic work?
Oh nice! I didn't know that. Well I already invested heavily in getting the remote working so the 8.8 would be viable. Not much reason to add the controls now. I think I will order the steering mounted one as well since I read that the receiver works for multiple transmitters.You could swap the screens if you choose (I bought both to test which I liked more):
Awesome!Crap I think I figured out the issue. Factory mic is 2.5 TRRS (three pole) and the joying mic is 2.5 TS (single pole). If there’s an adapter for that it should work. Idk I’ll look later. Heading out for a bit.
I believe only one of those is dedicated to calls, the top driver directional. The others (I think) are connected to other areas of the 4C, safety systems?Mine came with a bounty of microphones to choose from. I only found a wire for the one that was plugged into the Parrot.
The middle is the mic. The two on the side are part of the security system/immobilizer.Mine came with a bounty of microphones to choose from. I only found a wire for the one that was plugged into the Parrot.
I have mine in the same spot and the only thing I use it for is volume control since the rest is on the screen. I don't need to look at it to know to turn the knob one way or the other. I ordered the third option they sell and I am going to try and mount that flush in the same location when I get a little more time.That looks really nice, and matches the car's interior way better than the Joying steering wheel control. Unfortunately, that cup holder is too far back and requires taking my eyes off the road and my arm to contort in order to use it. Does it work in that position for you?
I mounted the steering wheel remote to the windshield wiper stalk. It seems like it will work good enough in that location. My only complaintsis are that there's a slight delay in making volume changes, I wish there were more programmable buttons, and I wish the backlight color was selectable.
That's what I like about this one, the volume changes are really quick. And yes, it would be cool if I could backlight it in yellow!That looks really nice, and matches the car's interior way better than the Joying steering wheel control. Unfortunately, that cup holder is too far back and requires taking my eyes off the road and my arm to contort in order to use it. Does it work in that position for you?
Volume control and the pause/mute options. Yes, you don't need to see to adjust the volume. And the mute button is in the center of the dial so it's easy to find without looking.I have mine in the same spot and the only thing I use it for is volume control since the rest is on the screen. I don't need to look at it to know to turn the knob one way or the other. I ordered the third option they sell and I am going to try and mount that flush in the same location when I get a little more time.
Whatever that is you can probably count me in.I am currently making something else for the 4C.![]()
I've plugged in the long AV cable to the "back" cable and "rear view camera" AV input from the headunit, and then connected that up to the rear camera with the long adapter. The power adapter is also connected to that same cable, with the camera & the long adapter's cables plugging into the long connector.Where are you getting power from to the camera? I took power from reverse light.
