61 - 80 of 92 Posts
Just got my car fitted with Michelin Pilot Sport 4S. Fronts were 215/35/18 and rears 245/35/19. All seems fine. A little closer to the ground due to the fronts not being available yet in the 40 aspect ratio, but other than that they feel slightly better than the Pilot Super Sports that I had on my vehicle. I checked with corporate and they were fine with me putting on a thinner tire.
Nice - could you post a side profile pic from distance so we can see the ground clearance please?
As much as I would love 4S on the front, I don't think I can afford another 0.5" lower ride height when I scrape everything already. Is the speedo/abs etc. ok? That's quite a bit smaller diameter.
It is night time right now. I will post a picture tomorrow.
I haven't had any problems with them so far. I have to get down a ramp every day out of the garage....no issues. I have speed bumps at work....no issues.
To give you some perspective for the smaller front tire:
Stock tires (205 * .40) = 82 mm sidewall height
Tread depth of 7.9 mm = worn down tire is at ~ 74 mm
New Tires (215 * .35) = 75.25 mm sidewall height
Tread depth of 7.5 mm = worn down tire at ~ 68 mm
So like new, the MPS4S can be taller than your old tires. When worn down, they are 6mm shorter than worn stock Pirelli. Look at 6mm on a ruler.....that's not much at all. That isn't even half of the width of the nail on my pinky. I'm not worried at all.
And like I said, I contacted corporate and got the approval. The tech I talked to even said they would be better than stock.
6-7 mm difference is about .25". I just went and measured with a ruler in my garage (its night will post side pictures tomorrow), and I'm at about ~4.4" at wheel and ~4.7 at nose.
Pics: (don't pay attention to nose scrap, that's when I had old tires and took a really bad dip very fast lol)
104289
104290
This is not at all scientific but what I'm trying to convey is that I think it is fine. I'm sure people on this forum have aftermarket suspensions and lowered the 4c. These tires, while smaller, are only a quarter of an inch difference. That's less than the tread depth of the stock tires! Are you worried about being too low to the ground when your tires wear out? If not, then these tires shouldn't be a worry either.
View attachment 104289 View attachment 104290
Looks fine to me. I'd be more worried if the new tyres had greater height, raising the CG. You're not going off-road and if you keep your eyes open for raised humps/lumps in the road, and we all do as our cars have little clearance to start with, then you should be fine.
Good to see, my fronts are due soon so I will consider it. Problem is roads here are terrible, my nose is already a mess. I scrape every time I come home no matter what I do, and there are a few routes I flat out cannot take because of the speed bumps.
If you are having trouble with speed bumps already, maybe think about getting a taller tire. A 215/40 is taller than stock and that might help. But like Alfanut said, that will slightly raise the center of gravity which could slightly affect performance. It is also a heavier tire. Like I said before though, we are taking about single digit percentage point differences, which should be hardly noticeable.
104301
I have just had Michelins put on:
225/40/18
255/35/19
They are slightly taller and so reads 2% slower (so you are going faster than you think). I have t say, the car is not only taller with fewer scraping issues already, but it looks so much better. The arches are much more filled out now.
Question:
I was recommended these sizes as being reasonable, does anybody know if I would have any issues tracking these tyres?
Umer
I still can’t find PS4S in that size? Where did you get them, or did you go for Cup2?
104391
104392
Good amount extra sidewall and width, I think 2% is ok. As long as you haven’t got TC lights flashing already you should be fine I think.
I’d really like some more sidewall myself, it’s painful scraping on my driveway every single time.
Is there anyway to import tyres? PS4S are in plenty of sizes abroad just not in the Uk!
We suffer from the same lack of choice here in Australia. It’s very frustrating. I know that doesn’t help you but knowing you’re not alone may be of some consolation.
Hmm we can get Eagle F1 SuperSports in the stock sizes here. Seems a pretty new tyre to compete with PS4S, not many reviews yet.
I got PSS fronts and PS4S rear, because they can't be had here in that size (which is stupidity).
Sorry, I forgot to clarify!
Thanks for the information above, that's super useful. No lights, no TPMS issues, it's great
Have read great things, but I'm a big fan of Michelin from previous cars, and at the price they were (under 600 for all 4 corners despite 2 steps up, fitted) was tempting.
Ultimately, the tyres alone have had a huge difference on how the car drives and they haven't even bedded in yet. The car still tramlines, but it doesn't throw you sideways, it is much more gentle. I didn't have alignment done yet because need new pads soon, sure that would have helped even more.
Managed to get new Front tyres sorted today. Eagle F1 SuperSport on the front, OEM size. PS4S on the back still but when they run out I'll be able to have F1 SuperSport all round.
For future reference, any owners in Somerset/Wiltshire area.
ProTyre Westbury have a Hunter Alignment rig which is actually set in the floor, so no lip/ramp to get up and the 4C fits no problem. It also has a neat build in jack thing with hockey pucks on so can safely lift the car.
I was there with Rob this morning and he was super helpful and let me get involved to make sure everything was going to plan, as it's not a typical car to deal with there. Will use them again for sure :).
Looks like Eagle F1 SuperSport R is a valid alternative, and they even got right size for our 18/19" wheels!
(Bottom of page)
However, I'm so happy with my Pilot Sport 4(not s), that I'll be very reluctant to try other brands.
(Bottom of page)
Goodyear are a good brand, they have a great reputation for making tyres. If I were to not buy Michelin, it would be them.
(I personally went Michelin, but Goodyear would still have been good)
Actually, I have Goodyear Asymmetric 2/3 (rear/front) on my daily driven BMW318d with M sport suspension , they are very good(In dry, stability, noise), but seemingly does not excel in the wet. So next change, I was planning to try Michelin to see if its the car or the tires.
My Mazda RX8 also has Goodyear Asymmetric 3, cabin noise reduced 2dB(very noticeable) compared to Vredstein Ultrac Sessanta. Havent pushed in the wet, used for occasional good weather 9000RPM punishment.
61 - 80 of 92 Posts
