Thanks to [email protected] for another great product. Eurocompulsion silicone intercooler hose replacement.... similar to all the other high performance EC/HPSI silicone hoses I have used on my Abarth from intake, boost retention valve and various replacement hoses.
Very easy to install.
1. Jimmy open stock crimp clamp on either side of the stock hose with flat head screwdriver.
2. Most challenging part is breaking the seal of the hose on either side and wiggling off hose. I heated either side of the hose with a heat gun to make the rubber more pliable and then used a plastic pry tool to disconnect the hose off the coupler.
3. You can lube up the inside of the EC hose with a dab of oil or sex lube and the hose easily slides on. Tighten provided new worm clamps and good to go! Took less than 30 minutes.
