1 - 4 of 4 Posts
my 2015 4CSE is blocked behind my stalled 92 spider veloce with a spark problem. Cranks but no spark. It has been super reliable in the past. I changed original plug wires and coil out with no luck. I used continuity light and found out no power to distributor. Relay or ECU? I can not drive either until I fix the electrical problem for the 92. Anyone know where I can find a wiring diagram to trace the source?
Help(Aiuto)!,
Melanjohnny
Are you measuring voltage across the coil terminals(+ and - connections on the coil)? or measuring from positive terminal of the coil and chassis ground?
1 - 4 of 4 Posts
