That’s nuts, why would you ruin the car with power steering it doesn’t need? I could steer it with the strength of one finger. A faster rack making it heavier would only help it.jamie seems to convert to power steering?
ask him
please keep inform.
I know what you mean. I find myself moving my right hand to the four o’clock position when cornering hard left and my left hand to the eight o’clock position when cornering to the right.It just means you turn the steering wheel a bit less but by all means, do get excited. Less physical movement! woohoo!! 😀
Seriously though, FOR ME...it’s the only way to make the car suitable to drive with hands fixed at 9/3 (give or take an hour) and therefore use the wheel mounted paddles well.
Anyway, quaife quick racks available off the shelf in 2.2, just not for our car.
I’m still trying to understand this.Philster, those issues are fixed with better tyres and geometry.
Power steering in my view is for luxury and ease, not fixing twitchiness on a carbon exotic that came with bad geometry and bad tyres.
The 4C manual mode demands approximately 9/3 technique to use it. 9/3 is practically impossible all of the time with our steering ratio. I know many attempt it and are satisfied but I am a perfectionist I suppose. I want to be able to actually keep one hand at each paddle all the time, and steer the car, even around hairpins. I don’t want to miss the change because I had to move my hand away from the paddle to make the turn.
I have explained myself more than adequately. If you don’t understand, I can’t help you other than to suggest you not using passive aggressive, mocking quotation marks to attempt to undermine me and then expect a civil discussion.I’m still trying to understand this.
In what situations do you find the wheel turned so much that you need to move your hands away from the paddles, and are still shifting?
The only one that I’ve come up with is a right (in your case, would be left) turn off a stop at a 90 degree junction.
In any other circumstance where the wheel is turned that much, you shoudn’t be shifting. If you are, then you aren’t driving the car to anywhere near its limits.
Rule of thumb is that prior to turning in, you select the gear that is appropriate for exiting the corner.
If you are “a perfectionist”, then this is the approach you should be taking.
Im not and it’s funny because it’s the other way round.. (as you know) again, ppl clearly object to me having an alternative opinion to theirs. They seem to take offence because I deem what is good enough for them inadequate for me.Don't be upset that others don't agree with you.
I will put you down as a maybe then shall I?Only ever have this issue going round a tiny roundabout so it's a non issue
On track 9 and 3 at all times
I would NOT want a faster rack when on track when running sticky tyres and a decent amount of negative camber. Completely different ball game turning the wheel at 70mph vs 130mph
