I agree, but unless you're turning the wheels standing still, it's pretty easy to rotate the steering wheel, even with wider tires. On my other cars, even with assisted steering I never standstill and rotate the wheel as this only kills the tires, instead I slowly move the car and rotate the wheel. Most of those coming from non assisted steering do that, while those having assisted steering since ever, not really. On 4C, as long as you're moving at least slowly, it's really easy to rotate the steering wheel, isn't it?
A bit more insight into to the 4C's steering...
One of the reasons the 4C has lack of self centering is low kingpin inclination angle in combination with low positive caster, which causes the car not to jack up the wheel on turning which makes the steering wheel feel light even without assist, but on the other hands the straight line stability is poor and even lacks a bit of feedback (it's hard to tell how loaded the front wheels are, as the jacking supposed to do but on a 4C there is, almost none. You can tell that by rotating the steering wheel while standing still and you can see that the car's hood/nose doesn't raise or lower). Make a full lock and take away slowly, you'll see that the steering wheel doesn't even self center. Alfa added relatively slow steering ratio to further ease the rotation of the steering wheel, but on the other at least for me it felt a bit unnatural. It requires a relatively lots of steering angle input for the oversteer corrections. You get used to it, but variable ratio would be a great improvement. Steady and calm on center, yet responsive on corrections. I'm not sure if we can make it as it's quite complicated though...
