We carry Selenia Quad oil for your 4C. Typically in stock. Ok we try to keep it in stock but it fly's out of here.
Petronas Selenia Quadrifoglio is a fully synthetic lubricant formulated to emphasize the sporting characteristics of Alfa Romeo engines with very high performance. It maximizes the sporting performance while maintaining total engine protection even in the most demanding driving conditions.
This latest generation lubricant allows maximum engine cleaning, a more efficient use of the power supplied and an extension of the oil change interval.
The new Selenia Quadrifoglio not only intended to lubricate and export heat but thanks to its high stability allows a perfect control of variable valve timing throughout the whole oil change interval.
Technical data
SAE 5W-40, ACEA C3
Approvals: FIAT 9.55535-GH2 CONTRACTUAL TECHNICAL REFERENCE N°F022.B18
For the following engines / model series:
alfissimo.com
We also carry MOTUL and RAVENOL in proper spec: FIAT 9.55535-GH2 5W-40
Technical data
SAE 5W-40, ACEA C3
- 1.8 TBi 4C
necessary quantity for one oil service 5.8 L (3x2L containers) (4C)
Selènia Quadrifoglio 5W40 (2L containers)
