1 - 20 of 23 Posts
Does anyone happen to know the weight of the 18/19 OEM fan blade wheels?
Apologies in advance if this has been covered somewhere, I searched the forum and was only able to find the weight for the OEM 17/18 and 18/19 teledial wheels.
Thanks in advance to anyone who can share this information.
Discussion Starter · #2 ·
Following up on this post with additional information. I contacted AR Customer Care to see if they had the information, or knew where it was available. The person I spoke with confirmed with a factory resource the following weights for the 18/19 OEM 10 spoke fan blade wheels:
Front 18 inch: 11.3 kg/24.9 Lbs.
Rear 19 inch: 12.7 kg/27.9 Lbs
Mods please feel free to add to the technical resource with the weights for the other OEM wheels if appropriate.
Info Teledials.....(y)
Genuine Alfa Romeo rim set in 18"/19" in the classic 5-hole design
Suitable for all Alfa 4C and 4C Spider
Colour: Matt black
The set consists of:
  • 2 pieces 7,0x18" offset 33 for the front
  • 2 pieces 8,5x19" offset 49 for the rear
The wheel bolts can be taken from the factory-mounted rims and are not included in the scope of delivery (as the rim badges)
Nethertheless a set of four rim badges is available as option
Weights (without rim badge):
18": 9,24 kg
19": 10,96 kg
Genuine Alfa Romeo accessory
(y)(y)(y)(y)
Good find! Wanted to buy an extra set fan blades and paint them in black. Going to pass on them. To much weigth! Thanks!
Reactions: smc4C
UP! Maybe somebody had the chance to weigh the fan blades? Would like to buy me a set in the future...
Interesting info. The teledial weight quoted is dead on compared to what I found when I weighed my actual wheels a couple years ago.
I’m not surprised that the fan wheels are heavier. The teledials are a forged wheel and the fans are not. I actually really like the aesthetic of the fan wheels but for 14lbs of additional unsparing mass, no thanks.
Discussion Starter · #10 ·
I have a new set of wheels, but it will likely be after the holidays before I’ll be able to install them. I’ll ask the shop doing the work if they’ll weigh the stock wheels and will share the info.
(y) (y) (y) (y)
Colour: Matt black
18": 9,24 kg
19": 10,96 kg
(y)(y)(y)(y)
Thanks to Qverde, Renesc we now know the weigth for the fan blades....
tibby said:
Hello, guess shipping to Belgium would be ridiculous ? Looking for an extra set fan blades.
Is there a possibility to weigh a front and a back wheel? please see topic...
www.4c-forums.com
Updated and Corrected: 18/19 Fan Blade Wheel Weight?
Does anyone happen to know the weight of the 18/19 OEM fan blade wheels? Apologies in advance if this has been covered somewhere, I searched the forum and was only able to find the weight for the OEM 17/18 and 18/19 teledial wheels. Thanks in advance to anyone who can share this information.
www.4c-forums.com
www.4c-forums.com
Buongiorno!
front: 8418 gram
rear : 10018 gram
Ciao!
Rene
That is much lighter than the weight figures AR provided. I’ll still have mine weighed when I swap wheels next month. A couple additional data points won’t hurt.
Wheel weigth numbers has been done by a seller of OEM Alfa parts. I'm curious as well about your numbers. (y)
I just weighed my dark fan blade wheels from my 2018 coupe.
Full disclosure, they were weighed with the OEM Pirelli tires and factory TPMS sensors, without center caps.
Front: 36.4 pounds
Rear: 44.2 pounds
Hello,
More people like to share the weigth of the oem 18/19 inch fan blades? Preferably without tires/tpms/wheelcaps.
Thanks!
Front: 36.4 pounds
Rear: 44.2 pounds
Found out the weight of
The 235/35R19 Pirelli P Zero has a diameter of 25.5", a width of 9.5", mounts on a 19" rim and has 815 revolutions per mile. It weighs 22 lbs, has a max load of 1356 lbs, a maximum air pressure of 50 psi, a tread depth of 10/32" and should be used on a rim width of 8-9.5".
So 44.2-22=22.2 lbs for the rear rim with tpms sensor
22.2 lbs= 10.07 kg (tpms inc.)
Reactions: Kanza
fronts:
Manufacturer‎Pirelli
Brand‎Pirelli
Model‎P ZERO
Item Weight‎18 pounds
Product Dimensions‎24.4 x 24.4 x 7.5 inches
Item model number‎2207300
Is Discontinued By Manufacturer‎No
Manufacturer Part Number‎2207300
Special Features‎Alfa Romeo 4C
Section Width‎205 Millimeters
Aspect Ratio‎40.0
Construction‎Radial
Rim Diameter‎18 Inches
Load Index Rating‎86.0
Speed Rating‎Yes
Tread Depth‎10 32nds
UTQG‎220AAA
Rim Width‎7.5 Inches
36.4-18=18.4 lbs (front wheel/tpms-tyre)
18.4lbs=8.34kg for front wheel with tpms
So:
double check
weight set measured without tpms/centercap by ReneSC (dealer of oem parts)
front: 8418 gram
rear : 10018 gram
weight set measured with tpms sensor/no centercap with info from the net by me
front: 8340 gram
rear: 10070 gram
Looks like the fan blades are light!!!
teledials:
18": 9240 gram
19": 10960 gram
1 - 20 of 23 Posts
