1 - 20 of 37 Posts
Time to install my Tarox rotors n pad m SS brake lines:). What brake fluid are u guys using?
DOT4.
Not a fan of the hyper-expensive race fluids in lightweight cars. They have to be flushed more often (more hygroscopic), yet their higher price discourages you from flushing. I prefer parts-store DOT4 flushed often. More than enough for our cars unless you've doubled the HP and are using crazy tires/aero or something like that.
Currently using Torque RT700. However, I'm starting to agree with Hornetball's approach. I have used the stock OEM fluid with good pads, and have never had issues with fade. The only issue I have ever had was a slight softness due to crappy braking technique. The Torque is quite expensive per bottle, and I flush every year (and may start doing 2 times a year). Due to this cost, I have been considering moving to Motul RBF600 (about $4/bottle cheaper). May even go cheaper and just flush more often (The cost to flush is about $100, as I'm too lazy to do it myself).
Yeah... I have looked at single person flushers over the years...but as I said "too lazy"...However, cheapness may overwhelm the laziness.... lol
Castrol REACT SRF DOT 4
Not cheap. But I was happy with it and will simply have it flushed annually.
There was a lot of popping and pinging from the brakes my first year on the track with the 4C, which I attributed to the stock brake fluid. The only changes I made in year two were new pads and fluid, and the noise went away almost completely. I don't think the noise had anything to do with the pads, but somebody could prove me wrong. Maybe my braking technique also improved, but don't bet on it!
Flushing is not a job I want to get into personally, and having brakes that work without a potential problem is too important to me. Maybe if I had more experience doing so, I wouldn't hesitate as much. But I'd rather practice on my mother in law's car a few times first. >:) Kidding!
YUP. SAME
CASTROL SRF all day!
+2
You can do half a dozen track weekends with one flush and the pedal will still be hard as a rock (tried it on other cars, not the 4C)
Sent from my ONEPLUS A5000 using Tapatalk
+3
Also run it in my Corvette and have never had a problem on the track.
Some nice discussion and comparison table in this blog:
http://trackdays.ie/best-racing-brake-fluid/
I have never heard of "popping and pinging" being a symptom of overheated brake fluid. Those sounds are almost always related to thermal expansion/contraction of dissimilar solid materials, especially metals. :huh:
The symptom you get from overheated brake fluid is a soft pedal.
Was suggested to me by others on this forum.
Yes, you might be right.
Just noted it was different this year and that was the major change.
I'd agree with two bottles - one litre will likely just work, but since you are probably flushing a different product out, you'll very probably waste some to make sure you clear all of the old out. And it doesn't hurt to have a bit left to top up with as your pads wear down.
My CDN$0.02 - but what do I know.
thanks so much
changing it first time in 2 years of ownership
hope previous owner did it
Alfa dealer asked $450 with my fluid
I will take it to regular shop, they take 150
I’ve used Motul RBF600 since I had braided lines fitted 12 months ago. Just renewed it at the last service a couple of months ago.
1 - 20 of 37 Posts
