1,081 - 1,100 of 3,373 Posts
Did my local track in NH today called Club Motorsports.
It is a closed 2.5 mile course with 15 turns and 250 feet elevation change
Tucked in the White Mountain area.
Weather great and the track having just opened is baby smooth and
It was not too busy. I have LE track package and hit 120 mph in the straight.
Here are pictures on and off track.
Very nice
The 4th braking light on the bottom, did you connected to the 3rd braking light?
Is there a light warning light with that light or only with LED bulbs?
I connected it to the right hand side light cluster. Is easy to get access, just remove the round plastic cap on the right hand side of the trunk, you will see the light cluster connector, remove that and use a voltmeter to check which wire is parking light, brake light and negative, connect it to the fourth light, the light on the photo is the parking light if the brake is depressed the red light will glow stronger. This is a aftermarket replacement light for Nissan Z370, no light error because is not replacing any light just a extra light so no drop in voltage.
that's great news! Did you mount it on the bumper or mesh?
