Hello fellas,
Had a chance to test drive Alpine - A110 on an AutoX event and thought you might care to hear our thoughts on a comparsion between A110 and the 4C,
So what's it like?
Exterior:
Well, the front end is not too appealing in the pictures, neither it is in live. I don't know, something is off. The side profile is OK, and the view from the rear is cool. It looks wide and sporty. The wheels in this particular car are too retro for my taste. It is narrower than a 4C and looks longer, less boxy. Forgive me my subjectivity, but in the looks contest, 4C is a clear winner here. It was embarrassing how much more attention the 4C got.
Interior:
No subjectivity here. A110's interior is level or two above 4C's. Materials, luxury, audio, the comfort. 4C feels like a kit car compared to A110. A110 is a winner here, no doubt. The only plus on the interior of the 4C is visible carbon fiber monocoque and super wide door sills, giving it a proper race car feel.
Comfort A110 is surprisingly comfortable car. It provides a decent in-cabin feel. Audio is OK, the interior is quiet and the car feels soft to drive. 4C has really just a basic comfort (AC), very mediocre audio system, loud interior and passenger seat is not even adjustable, so it is definitely not a comfortable car.
Engine:
This A110 was the basic version, with 250hp engine. It feels pretty much the same as stock 4C does. You can hear less turbo, but more air intake sound (like from N/A engines), although the engine sound itself is not nearly as noticeable in the cabin as it is in the 4C. It pops and bangs quite a lot on every aggressive throttle lift off. The engine feel slightly less torquey and more linear. The tunability is probably slightly better than on a 4C, the position of the engine itself is lower and the turbo is facing towards the rear of the car, which provides far better cooling capabilities than 4C has. Nothing wrong with 4C engine, but I believe the A110 has a bit of an edge here over 4C.
Gearbox:
A110's 7-speed DCT feels smoother and slightly faster. Especially on drive-away it feels less clunky and noisy. The paddle shifts are part of interior, but they are more robust, all aluminum, compared to 4C's plastic ones. It has slight edge over 4C's TCT.
Weight:
With about 100kg more than 4C, nothing to explain here. 4C is a winner.
Suspension, chassis:
A110 has double wishbones front and rear compared to 4C having double wishbones at front and MacPherson at the rear. On the track with a few cm's of travel it is hard to evaluate how much of an advantage the double wishbone is compared to MacPherson, but we can assume that technically the A110 has superior suspension compared to 4C, but that doesn't necessary make the 4C slower or less capable. The monocoque carbon fiber tub in a 4C is a no brainer over A110's aluminum.
Brakes:
The 4C uses decent 4-pot Brembo caliper at front, and a generic, 1-pot, sliding TRW caliper at the rear - mediocre at best we can say. It's almost absurd, but it gets the job done. The pedal box, the brake pedal feel and modulation on a 4C is superb though. 4C does feel a bit too much front biased though and it screams for an upgraded rear brake calipers. The A110 has 4-pot calipers front and rear so that's a clear advantage over 4C and while modulation is OK, the entire setup feels a bit spongy and soft. The brake balance feels well biased though. I would call it a tie on the brakes comparison. Combining brake specs of both cars together, would make for a perfect braking system.
Grip: While 4C has about 10% less weight (1000kg) vs 1100kg (A110), the A110 has slightly superior suspension layout (double wishbones front and rear). However you can't deny the laws of physics, so 4C will generate higher cornering speeds due to its lower weight, Alpine doesn't feel any heavier or less capable compared to a stock 4C. While none of these two cars have noticeable aero features, this is pretty much all about the tires and weight. The one with better tires will win. Both cars, on same tires, the lighter one will win.
Handling / driveability:
That's tricky to review as my understanding of handling / driveability is quite different than most of car reviews you can read. Handling / driveability and grip are two separate things. The car can handle good, but that doesn't mean it's necessary going to be fast or has lots of grip. Or the other way around. The car can have lots of grip, but it's not going too have a particular good, easy and forgiving handling. F1 cars have mind fuzzing grip, but their handling / driveability is not really easy to tame. In general, the more "racey" the car is, the higher is the grip limit but less forgiving and harder to handle the car becomes. Driving such car on the limit, yields superior lap times, but it requires far more precise and skillful driving. The room for driver's error margin narrows significantly. Things that contribute the most to this are aggressive alignment, tires and stiff suspension. There are also other things that contribute to this, but let's not get too much in to the details at this point and let's focus to A110 vs. 4C comparison.
As mentioned, the A110 has superior suspension layout and slightly better weight distribution (44/56) vs. 40/60 (4C), but 4C is about 100kg lighter and has stiffer setup suspension, with noticeably less dive, squat and body roll. With rather softly setup suspension, the A110 feels a bit too floaty, especially on the weight transitions, but it soaks up the curbs nicely, while 4C carves through the curves better, with less body roll, but it gets more unsettled by driving over the curbs. Although the power assisted steering on A110 is rather good, the unassisted, direct 4C's steering provides more feedback and precision, making the 4C easier to read the limits of its adhesion. The A110 also feels more like RWD layout car, with lots of tendency to drift and stay in drift, than 4C which feels like a classic MR layout car. On throttle lift off, the 4C will tend to oversteer, while A110 feels more neutral. On the throttle, accelerating hard out of the corners, the 4C will thrust and provide immense grip, which will rarely turn in to the oversteer, unless the surface is slippery, while A110 will easily oversteer which is not a very common for a MR layout cars. This is probably due to slightly more rear biased weight distribution on 4C and differently set up suspension. Overall, the A110 feels easier to drive on the limit (better handling), but less rewarding if precision driving is your thing. If you like messing around with drifting or if your driving style is a bit rough, on the wild side perhaps, then A110 is the thing. If you care about pure performance and like smooth and precise driving, then 4C it is. It offers faster lap times when driven properly, no doubt.
Tunability:
While the A110 definitely has the tuning potential, the fact that it is available in European market only, there is basically no tuning or upgrade suppliers for this car, which leaves you with a pretty much stock A110. The track builds, race builds and tuning market for the 4C on the other hand, is impressive given the number of cars made. 4C is a clear winner hear.
Tracking:
A110 has solid out of box performance, but 4C is more track orientated. The tuning market for A110 is virtually non existing, while 4C tuning market is capable of fulfilling all your track needs. both cars are cheap to run on track unless you crash them.
Overall:
A110 is a well composed and proper sports car. It's comfortable, yet capable. It provides a good driving experience and feels a good all-arounder (track, street). It feels like a Cayman, just slightly less powerfull and slightly lighter. Nothing new honestly and plenty of choice in this segment. The 4C on the other hand is entirely different. It's a kit car, homologated to be driven on the roads. It's not comfortable, it's not good all-arounder, but it's immersive to the point you can forgive it all it's hardcore-ness. If you don't care about comfort, about the radio and other luxury stuff and you just want to shred it, then this is it. It's a light, nimble, high grip, non forgiving bolide. Keep your 4C as we probably won't have another chance in a lifetime to own a crazy car as 4C is.
Rating:
Exterior: A110 (5) 4C (9)
Interior: A110 (8) 4C (5)
Comfort: A110 (7) 4C (2)
Engine: A110 (7) 4C (6)
Gearbox: A110 (7) 4C (6)
Weight: A110 (8) 4C (10)
Suspension / chassis: A110 (8) 4C (8)
Brakes: A110 (7) 4C (7)
Grip: A110 (7) 4C (9)
Handling / driveability: A110 (8) 4C (7)
Tunability: A110 (1) 4C (8)
Tracking: A110 (6) 4C (9)
Overall: A110 (77) 4C (86)
Fun fact:
- They barely let me drive the A110 with the Alfa Romeo T-shirt.
- It took me 6 laps to found the audio controls and turn down the radio volume to hear the car better
